I am currently running a non-original, over-the-counter, GM tach drive distributor (part number unknown). I'm in the process of putting in a set of new points, and I noticed there was no cam lubricator mounted anywhere, to lube the breaker cam. Could this be normal? Do not all distributors lube the breaker cam? I did notice a possible mounting hole for a cam lubricator on the breaker plate. Can I get the lubricator at the parts store?
Thanks, Chris
Thanks, Chris
