I am trying to get the brakes (cylinders) off of my 60 vette, and am having difficulty. Have the shoes and all the actuation hardware off, and there appears to be a single 1 1/16" bolt holding a backing plate and the rear brake cylinder to the axle housing. The brake fluid line comes right into the back of this. The 1 1/16" bolt appears to have a similar nut on the back of the axel plate.
This needs to come off to replace/restore the brake cylinder, correct?? Is it just one of those WD40 and a couple of hard wacks with a mallet on the wrench, or am I going to forever destroy something?
Should I get the cylinder restored, or buy new ones (4)? Is there a "kit" that has the related hardware as well...the srpings and pins holding the brake shoes on are holding, but quite rusted and should probably be repalced with the rest.
RICK
RICK
