build sheet - NCRS Discussion Boards
build sheet
  • John Boudreau
    build sheet
    Where is the factory build sheet hidden in a78 pace car?
    Re: build sheet
    John-----
    Just about the same place it was hidden on other 67+ Corvettes. You'll find it on the upper right side of the fuel tank, but it's difficult or impossible to access with the fuel tank installed in the car, especially on a 78-82 Corvette.
    You MAY also find a copy of it tucked up under the dash in one of several locations including above the steering column or on top of the heater/A/C box. On later C3s there may also be a copy under the carpets. But, none of these locations are "for sure". Someone may have been there before and removed it, too.
      Correction
      I should have said upper LEFT side of the tank and NOT the upper right side.
