63-72 Exhaust Systems - NCRS Discussion Boards
    I've had a few off-board questions regarding exhaust systems, so I thought that I'd post a little information to the board that might clear up some confusion that might exist on this subject.
    In general, the questions seem to have involved how to create an original-appearing exhaust system or which clamps are correct for the muffler-to-exhaust pipe joint. As a matter of fact, NO clamps were used for the muffler to exhaust pipe joint since the original exhaust pipes were welded to the muffler AT THE MUFFLER INLET. Also, one cannot create an original configuration exhaust system by welding a SERVICE muffler, either an original GM SERVICE muffler or any other SERVICE muffler, to the exhaust pipe. SERVICE mufflers utilize a short extension and a bell (or "slip") joint on the inlet side. On original PRODUCTION exhaust systems, no such joint was used. Such a joint "sticks out like a sore thumb", regardless of whether it's clamped or welded.
    Original 63-72 Corvette exhaust systems utilized only 4 clamps----2 at the joint between the forward and rear exhaust pipes which also clamp the exhaust pipes to the "oxbow" bracket at the transmission crossmember AND 2 which clamp the exhaust tips to the mufflers. That's it.
    In order to achieve as original configuration exhaust system, one of the following must be done:
    1) acquire an NOS GM N-11 "off road" exhaust system. These systems have the rear exhaust pipe welded to the muffler as was originally done for both standard and N-11 exhaust systems in PRODUCTION. In SERVICE, only the N-11 system was sold this way. These systems are VERY hard to locate, OR,
    2) acquire a reproduction exhaust system which has the mufflers welded to the rear exhaust pipes, as original. These systems are available from Allen's Corvette Exhaust Systems and several others. They are not a perfect match to the originals, but they are as close as you will come to an original configuration system.
    Also, keep in mind that all original Corvette exhaust systems were plain carbon steel. This rusts almost immediately. However, you can obtain the reproduction, as-original configuration systems in carbon steel, aluminized, and stainless steel. Aluminized is probably the best compromise for a driven car. Plain carbon steel works well for "trailer queens".
  • Jeff Bratton
    Re: 63-72 Exhaust Systems
    was the off road system ever factory installed on 63? i have one with that system. i was told it was dealer installed??
      Jeff-----
      The N-11 system was never installed on a 1963 model to my knowledge.`It's possible, I suppose, that a few might have gotten out on Z-06 cars. While these systems were still available in SERVICE (which they were for about 30 years), it was VERY easy for anyone to retro-fit them to a car. In fact, it was easier to install an N-11 system than a standard SERVICE exhaust system.
        • 15610
        To the best of my knowledge the N-11 pipe/muffler assemblies never had the kinks to fit the seat wells on early to mid production '63s.
        The N-11 service assembly numbers are 3845735/6, and these should match
        the AIM numbers from '64 to '67.
        Also, I believe these numbers are debossed in the mufflers, which makes them easy to identify.
        Only a '63 without the seat wells will accept the N-11 system, and this might be why they were never released for '63 production as the early floorpan was still being used fairly late in production.
        • bob downs
          allens exhaust systems
          allens makes nice exhaust systems. their mufflers are guaranteed for life. sometimes the pipes are the wrong length or the cross over tubes are welded at an angle but other than that there nice systems. it seems that every time i use an aluminized system on a c-1 the right side never fits right.
