69 427/400 carb linkage adjustment - NCRS Discussion Boards
  • Frank/Paula Lowery
    Does anyone know of someone in the Birmingham, AL area that has experience with tri-power set-ups? The particular car is a 69 427/400. The carbs were sent off to Jerry Luck Motorsports for a rebuild/refinish. They came back looking and running great. Only problem is the new linkage, from Paragon, is not adjusting out correctly. Because of this we have removed the linkage and are running on only the center carb. Which still runs great on just this one. Thanks in advance for any help.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 69 427/400 carb linkage adjustment
    They are not that difficult to adjust assuming that the linkage is installed properly. You get the center one adjusted and make sure that the rears are fully seated, then adjust the links untill they just slide into the holes on the end carbs.
