Has anyone replaced the fiberglass console piece on a 58-60? If so, how is the old one cut out so the new one can be re-glassed to the underside of the dash? How does the bottom attach to the tunnel (I haven't pulled back the carpet yet)? I can't even see a metal bracket on the back (bottom) of the console piece, just a large mass of resin. The AIM shows a bracket.
The reason I am considering a replacement is the original console has a horizontal crack from one side to the other, where the radio was not supported and the weight of the radio cracked it. The other reason I am considering replacement is the new console piece I already purchased (in haste!)sitting here in front of me. The backside of the crack has been re-glassed, but the front has not been worked on. The top half of the crack sticks out slightly from the lower half. If I decided to just repair the exterior side of the crack, would I need to re-glass over it and sand smooth or just fill crack with bondo, epoxy, or resin and sand smooth? I have 30 days to send the new console back to CC. Your opinions would be greatly appreciated.
