I have removed the master cylinder on my 1960, and it apears to be leaking quite a bit from the rear seal...the boot is full of fluid, and cylinder is almost empty.
Thought about "upgrade" to disc brakes, but after talking with some and researching the archives, sounds like the disc brakes are only worth their weight as a paper weight, no more. I am rebuilding the front and rear as per original specs....
I have seen in MidAmerica, and others, kits to rebuild the master cylinder. Anyone have any experience with those kits? Do I need any special tools..no machining is there? Pretty easy to refurbish the old master cylinder? Works just fine that way or best to get a replacement NOS cylinder?
RICK
RICK
