I was pop riveting the ends on my 1967 dash and the rivets would not pull all the way thru before separating. They would break about 1 inch from the ends of the stem, leaving a stub to cut off. Has anyone else had this problem? I bought these rivets from Long Island Corvette.
pop rivets
Re: pop rivets
no rivet pulls all the way through. there designed to break close to the ball head but this doesn't happen all the time. you can take a punch and tap the stem in and let it go or tap the stem through and drill out and redo. you can try and make a cut mark where you want the rivet stem to break. this works for me.- Top
