C3 idler pulley and belts setup - NCRS Discussion Boards
  • John A.
    • August 31, 2002
    • 172
  • Craig S.
    • June 30, 1997
    • 2471
    Re: C3 idler pulley and belts setup
    John - you are correct...it pushes inward to tension the belt, and rides on the outside of the belt. Craig
    • David N.
      • June 30, 1991
      • 142
      John, If you go to Paragon's catalog at this webpage:
      and go to part #2118 and click on the "PIC", a picture of the assembly comes up. It is the outside idler.
      David Nims 19639
      • John A.
        • August 31, 2002
        • 172
        Craig and David,
        Thanks for the feed back - This should get me further along... I hope. Have you had any problems running this configuration... (trying to understand why the pulley was removed?)?
          • 43193
          John-----
          The 69-74 big block with AC used a NON-GROOVED idler pulley as you have described. The AIM drawing might be a "generic" sort of drawing with "carryover" from 1968 set-up which used a grooved pulley.
          • Craig S.
            • June 30, 1997
            • 2471
            John, as Joe mentions, it was removed in 1969. The new style works very well, no problems whatsoever...Craig
