I am planning to change the front seal on my '63 4 speed. What is the easiest method for draining the diff lube ? Thanks.
Draining Differential
Re: Draining Differential
If you mean prior to pulling the pinion seal, Peter, there isn't an effective way. But it's going to happen mostly on its own when you pop the seal so have a catch can ready.
You could stick a suction tube through the fill hole but that takes a long time and doesn't give you a complete drain.- Top
