Many thanks for the info Bill Clupper . On this late car, august, there is not vacume line from the carb to the vacume advance on the distributor.There appears to be only centrifical advance used. I will check the timing and the advance if possible. There are no thermostatic exhaust valves in the exhaust system either that I can see, or are they inside the exhaust manifold where the exhaust pipe bolts on. ie hidden?
Thanks again Bill,
Jack Steele
Thanks again Bill,
Jack Steele
