63 wire harness grommet - NCRS Discussion Boards
  • Paul E. Young
    Does anyone know where I can purchase a rear wire harness grommet that seals the wire harness and antenna in the rear of the car where it enters the passenger compartment. I can't seem to locate one in any of my catologues.
    Re: 63 wire harness grommet
    Paul------
    The grommet of which you speak was GM #3784177. It was a 2 hole grommet with a one hole for the rear wiring harness and one hole for the antenna cable for cars so-equipped. This particular grommet was also used for some firewall applications. However, it was NEVER available in SERVICE from GM. For SERVICE, GM supplied only a 4 hole grommet of GM #3838273. That piece was discontinued in September, 1984.
    While you could never get the 3784177 grommet from GM, you CAN get one from Dr. Rebuild. His part number is 1014649.
    • Paul E. Young
      Thanks Joe, the one I removed only had one hole so I thought that it was the right one. After 40 years who knows what was put in there. Paul
      • Dave K.
        • November 1, 1999
        • 951
        Just purchased one from Corvette World, Greensburg, Pa. As Joe mentioned, it is the same grommet used on firewall for oil pressure gage tubing.
        Dave Kitch
