'58 PowerGlide Linkage
  • Steve D.
    • October 1, 2000
    • 17
    #1
    Throttle Valve Linkage Adjustment
    I'm concerned. I am putting the lever "b" on my cast iron powerglide and am following the steps in the ST-12 Section 7-4. The lever attached to the shaft ok, I even invented a make-do fixture to position it correctly. No problem in assembly, My concern relates to free movement.
    By eye, this "b" lever has a free movement around the shaft of only approx 10 - 20 degrees, with hard "metallic" stops on both ends. When I assemble the other linkage members, rod "g" (which attachs to the carburator)has a back and forth freedom of movement of 3/4 in. total.
    Is this small movement correct?
    Steve Drake
  • Roy Braatz
    Re: '58 PowerGlide Linkage
    Yes , but as you pull on rod G you should feel spring tention. Now ,with the carb wide open , choke rod of it's stop and open, rod G is adjusted to connect in to the carb linkage.
