No picture, just words and measurements. This is a three level pan stepping down from 1 to 3 and all measurements are from the front unless otherwise noted. 1st step starts slope down to #2 at about 3 1/2" and 2nd step is level at about 5 3/4"; slope down to #3 begins at about 12" and this slope is "steeper" than that from 1 to 2; step 3 is level at 14" and extends 8". Drain hole is centered in the middle and 3" from the BACK.
On the underside, the pan has two deep wrinkles on each side where it goes from step 2 to step 3.
On both sides, there are two 1" long depressions where it goes from step 2 to step 3.
On both sides, there is one 6 1/2" long depression in the approximate center of step 3.
Back of the pan has wrinkles in no discernible pattern.
No trap door, just forward baffle in front of oil pickup area.
Is this #3789629 pan that appears in the October 1961 Parts Book out of nowhere and is declared for 57-62 or ??????
