Re: 1960 Corvette - NCRS Discussion Boards
Re: 1960 Corvette
  • Ed Jennings
    Re: 1960 Corvette
    VIN derivitives were not added until sometime mid year 60 or 61. I don't remember which. You need to see what the engine casting date is. It will require removal of the road draft tube probably to be able to read it. Form the serial number (VIN) you can determine the car's approximate build date. The engine casting date should preceed the build date, but not be more than 6 mos earlier.
