'58 wiper trans cables installed - NCRS Discussion Boards
  • Mike G.
    • April 30, 2001
    • 180
    A few days ago, I mentioned that the cables from the left wiper transmission were approximately equal, yet on the right trans, the inner (upper) cable was always longer than the outer (lower) cable. Well, to put some closure on this, everything hooked up just fine. I used the excellent article by Joe Calcagno from the Restorer CD-ROM. I do have a few thoughts not covered previously.
    1. I found it easier to hook the cables up with the motor NOT mounted on the plate. This way, for the second cable (the hard one) on each transmission, I could rotate the wiper motor plate rotor (it wouldn't rotate if the motor was on it) so that the cable end would slide in sideways, rather than wrapping around and then slipping into the slot. This way, less slack is required.
    2. If you do hook up the motor first, make sure the rotor is not 180* off. If that happens, you will have to swap rotor groove pairs (1&4 vs 2&3) for the two transmissions. I'm not sure this is really a problem, in fact, my car was originally hooked up this way (factory or Bubba?). But in our neverending quest to be like everyone else, it's probably best to do it the way Joe draws in his article. Of course, if you do the cables first, this "error" is not possible.
    3. Have your helper who pushes on the trans while you pull out slack wear gloves. Otherwise, your aggressive cable pulling may result in the trans top trying to bore a hole into the hand of your former helper.
    4. There are stops on the transmissions themselves that limit the trans' travel to about 2/3 of a turn. These serve no purpose in the actual operation of the wipers. The motor stops all by itself in both directions without any assistance from those stops. I mistakenly thought the opposite, so I sent a trans to Mary Jo to fix one of the stops. Her husband did fast, excellent work, but it was a waste of $60.
    5. If you think #4 proved I'm ignorant, check this: I tested the motor before installation. Hooked up some battery leads, slid the slider (switch) and presto, perfect operation! Now, this is all new stuff to me, so I wasn't sure which position was off. I tried all three positions, but the wiper was still moving in all three. Uh, oh, must be a short or something! An embarrassing amount of time later, I realized that in "off," the wiper first moves the wipers into "park" before stopping. I had been impatiently moving the switch to other positions before it parked!
    6. The bark of this job was much worse than the bite. On my car at least, there was sufficient slack that I had each cable hooked on pretty much by the end of my first "Get the **** on there, you *****."
    7. Finally, I believe the difference is length of the passenger side transmission cables is actually necessary because of the geometry of the whole thing. Of course, I could be wrong.
  • Ed Jennings
    Re: '58 wiper trans cables installed
    At last!!!! Glad to hear your were successful. Wish you would have asked about the stops. Might have save $60. Then again, maybe they are supposed to limit the travel if the motor is out of kilter. I doubt it, but you never know. I think they are there to limit travel during installation and keep everything together.
    • Al C.
      • July 31, 1999
      • 274
      Mike -
      Congratulations on your success, and thank you very much for telling us the tricks that can keep our toungues civil when/if we have to do it.
      ... Al '58 #378 245hp driving soon (?)
      • Mark Malone
        Mike,
        I had similar problems with mine some time back when the drivers side cable broke.
        I spent many frustrating hours with the stupid jiggers and I found that my transmissions are siezed so you cant push them down for tensioning so in the end I used a small stainless turnbuckle to tension the cable.
        After getting everything hunky doory I found that the motor is just about shot so now I don't take the 59 out unless there are clear sky's which suits my unrestored leaky convertible top anyway!
        Mark.
        • Mike G.
          • April 30, 2001
          • 180
          Mark-
          I remember reading your turnbuckle technique last year and was gonna use it if I had too much trouble doing it the right way! Seems to me your design is better anyway! But alas, I got lucky, and have a wiper setup worthy of flight judging! The rest of the car, tough . . .
