rear differential removal on 71 - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    I have been trying to figure out how to remove my differential from the car. I have the rear compartment completely bare. I have remove the side 1/2 shafts and loosend the 2 bolts on the cross member, disconnected the transmission at the U-joint. What is holding this thing in? I have used a crowbar between the cross member and the frame but do not want to break something.
    Any ideas would be appreciated.
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Jim T.
    • March 1, 1993
    • 5351
    Re: rear differential removal on 71
    Go through the archives on this, there are several posts on the removal of the crossmember. One such post I think I remember is by Joe Lucia. Good luck.
    • Ralph A.
      • May 31, 2002
      • 236
      Found the article, thanks for the help *NM*
      Ralph Adams
      NCRS: 38137 LA: 112
      Slidell, LA 70461
      • Chuck R.
        • April 30, 1999
        • 1434
        Hi Ralph:
        Heres what I found out on my very rusty 68
        First of all, I removed the differential with the leaf spring still attached.
        I started by pulling the half/drive shafts free from differential.
        I then took the strain off of one of the spring end link assemblys with my floor jack and pulled the link assemblies apart. I then slowly released the strain from the spring. Same process on the opposite side. Be super careful as there is a major amount of explosive power in those springs!
        Next I removed the snubber mount assembly.
        Next I removed the four bolts holding the differential up to the crossmember.
        With the jack underneath, I dropped the whole assembly to the floor.
        Now.... if the two bolts your talking about are the crossmember sombrero mounts, then yes there are just the two bolts.
        What I had to do there, was liberally spray the rubber mounts with WD-40 and put constant down pressure on the end of the crossmember with a pinch bar.
        My original north country mounts popped free in a matter of a couple of minutes.
        After I got the mount free, I immediately wiped the WD-40 from the rubber mounts
        Let me know how you make out.
        Chuck #32205
