69 vette front end lights..monza?? - NCRS Discussion Boards
  • TR69
    I have a 69 conv with a front end with no pop up head lights.They were removed and the headlight section needs brackets for the headlights...I believe they are called monza..?..wondering if anyone else has installed the supports..I have them but cant figure out how they go...help??
  • G B.
    • December 1, 1974
    • 1407
    Do you have frogeyes?
    I've seen two fixed headlight systems that could be inserted into the stock openings of a '68 -'82 body. One type was an aftermarket set-up that used modern rectangular headlights. The other type was offered by GM as part of their racing "distance kit". It used round sealed beams like the originals. Because they stuck up above the surrounding fiberglass, the clear plexiglass covers were called "frogeyes" by the public.
    Which of these headlight types do you have? They use different mounting brackets.
    • TR69
      Re: Do you have frogeyes?
      no, no frog eyes..they will not stick up..kinda look like a camaro as they will or appear they will be set back in under the hood....
