If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Was there a vapor barrier (paper shielding) between the door panel and the door itself? Mine doesn't seem to have it(65 conv.). Maybe it should have? In the AIM it states clearly it did, ZIP-products sells them. But so far I have not heared about it. Anyone with an answer?
Yes, it should. The "correct" type should be brown kraft paper with black backing, available from the better Corvette parts houses. The replacement type (plastic) will possibly be more effective, and cost less, but if you desire to have your car judged, and you use the modern stuff, then you better make sure that none of it is visible after the door trim is installed.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
