I know that the consensus is that '66 rear spindle supports were painted semi-gloss black, which I'm about to do. My question is, what surfaces should not have paint? I'm assuming that the vertical parallel sides of the two lower ears should not have paint since they were probably machined after painting. But what other surfaces shouldn't have paint? How about the parallel flat areas on the inboard and outboard sides of the support, through which the 4 trailing arm bolts pass? Should these be bare? What about the two small flats at the very bottom of the lower ears?
Gary
Gary
