Hole in front of courtesy light ('58) - NCRS Discussion Boards
  • Mike G.
    • April 30, 2001
    • 180
    Putting in the dash pad, I cut out the hole for the courtesy light (under the mirror). There's a hole just in front of it. I think this was for a power soft top switch, which I don't have. So I assume I don't cut out the hole in the dash pad, correct?
  • Loren L.
    • April 30, 1976
    • 4104
    Wrong! *NM*
    • Clark McEwen
      Re: Hole in front of courtesy light ('58)
      I think what Loren is trying to say is that all car had the hole for the PT switch even if they did not have the PT.
      Clark
      • Mike G.
        • April 30, 2001
        • 180
        Was it left as a plain hole?
        Clark, thank you for the clearer answer! Was there a trim plate or something that went over the hole, or did they just cut the hole and leave it at that?
        • Ed Jennings
          Re: Was it left as a plain hole?
          The hole in the fiberglass is cut, but not the hole in the pad. At least thay's the way the ones I've taken apart have been.
          • Mike G.
            • April 30, 2001
            • 180
            Thanks Ed and Clark! *NM*
            • John M.
              • January 1, 1999
              • 1553
              Ed,
              The judges allways look for a hole cutout in the pad, regardless of whether the car has a power top switch or not. I belive the JG has apicture of what it should look like.
              Regards, John McGraw
              • Mike E.
                • February 28, 1975
                • 5134
                The dozens and dozens and dozens of original-pad 61's and 62's I've looked at in the last 28 years all have had cut-outs in the pad.
                  Agree....
                  with Rev. Mike. I've yet to find a footnote in an AIM book telling assy line folks to 'prep' the dash pad by hogging a hole for the power top actuator switch....
                  • Dave S.
                    • August 31, 1992
                    • 2918
                    Does anyone have a picture of it????
                    I recall I did the cut out on the new dash pad on the 59, but my 61 is missing the cutout and the 61/62 JG does not show a picture. Is there someone who could refer me to a picture??? Thanks
                    • Mike G.
                      • April 30, 2001
                      • 180
                      Re: Does anyone have a picture of it????
                      I have a shot from another car that's not fair, not great. I can scan and send it, but it would be a day or two before I can get to it. The shot doesn't show a whole lot, though. Just that there is an "undecorated" hole just forward of the courtesy light. I personally don't like the look, so I'm leaving it uncut.
                      If you want the hole, reach in from above and there will be a hole in the fiberglass. Poke a sharp nail (awl won't fit) and you'll have your location. Then from underneath (the side you can see), cut away with an exacto knife.
                      I still haven't installed my speaker, so if you like, I can send a shot today of what that inside fiberglass area looks like.
