I would like to know if there is a good way to flush out brake lines. The car sat for ten years in a garage, (almost a barn story) the brake fluid turned to slug. I'm installing a brake kit and was trying save the brake lines. Thanks for any suggestions.
C-1 flushing brake lines
Re: C-1 flushing brake lines
I agree with Patrick, trying to salvage the old lines is a blueprint for disaster. If the brake system is as bad as you say then there is a good possibility that the lines are corroded on the inside. With a single master cylinder system system, one pinhole equals zero brakes! Replace the lines.
Regards, John McGraw- Top
