C-1 flushing brake lines
  • Paul Baermann
    #1
    I would like to know if there is a good way to flush out brake lines. The car sat for ten years in a garage, (almost a barn story) the brake fluid turned to slug. I'm installing a brake kit and was trying save the brake lines. Thanks for any suggestions.
  • Larry P.
    • July 1, 1999
    • 481
    Re: C-1 flushing brake lines
    I'll let the experts respond to flushing. If you decide to replace them, I have an extra, new, full set of brake lines. Email me off line.
    Larry
    • Patrick T.
      • October 1, 1999
      • 1286
      Replace the brake lines.
      • John M.
        • January 1, 1999
        • 8
        I agree with Patrick, trying to salvage the old lines is a blueprint for disaster. If the brake system is as bad as you say then there is a good possibility that the lines are corroded on the inside. With a single master cylinder system system, one pinhole equals zero brakes! Replace the lines.
        Regards, John McGraw
