C1 Gas tank strap retainers - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    I have the straps and have ordered the front retainers. I guess I will see when they get here. I'm curious how they will attach. I see that the rears use a bolt thru a metal backing plate. The front apears to be oriented into the holes in the fiberglass. I don't see any metal backing or mounting provision anywhere and can't see anything from the books. How do they fit? (60)
    Larry
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 Gas tank strap retainers
    Larry,
    The front end has pins through a loop in the end of the strap, and that pin engages some metal fork-shaped plates that are attached to the underbody.
    Regards, John McGraw
      Larry -
      There are retainers riveted to the underbody for the pins that go through the front of the straps - if yours are missing, Paragon has them.
