Mid Year Strut Rod Installation Assistance Needed - NCRS Discussion Boards
  • Richard L.
    • May 31, 1988
    • 156
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Mid Year Strut Rod Installation Assistance Nee
    Thats normal especially if you to not raise the wheel into its loaded position first. I would suggest that you remove the spring bolt if you havent already and push up on the wheel to assemble the rod.
    • Richard L.
      • May 31, 1988
      • 156
      Thanks for the Response, Wayne...
      Raised the Trailing Arm and things got much more user friendly. Still had to do a little coaxing to get them in. But in they are, and I have a new "Alignment Punch" which took out the final stubbornness of the alignment issue for the insertion of the respective strut rod shaft.
      Didn't have to remove the spring bolt...
      Thanks Again for the Advice...
      Rick
