C-3; '72 A\C Bracket Question - NCRS Discussion Boards
  • Bill Lloyd #33481
    I have a 72 Base engine roadster. The car has/had factory A/C. The previous owner added headers to the car. He did save the compressor but not the exhaust manifolds. I want to restore the compressor back. Can I use the stock bracket with spacers until I can get the correct part number exhaust manifolds? I am interested in any solution that would work until I can locate the correct gear. Thanks.
    Bill
  • Edward McComas
    Re: C-3; '72 A\C Bracket Question
    I had this situation on a 73 a few years ago. As I recall, you can use the
    factory front bracket, but you have to get a bracket from the header manufacturer for the rear compressor mount.
