Re: 1956 Power Top Limit Switch Mechanicals
Here are the relays and wiring. It's simply splitting the solenoid load wire out of the switch circuit and into the relays which are controlled by the 4 normal limit and safety switch paths. I chose to source the feed for the relays from the Dash Switch #12 Red tap for the pump motor. This keeps the feed wire in the trunk unpowered, and only live when the Power Top function is used. I also installed a 20A inline fuse at the dash switch tap point. The relays(with mount tabs) mounted easily to each solenoid cover corner using the existing screw holes. Using 90* terminals, I was able to keep the modification rearward height covered up with the stock bulged division panel. This would keep the modification unobtrusive if the car is being judged.
BTW, each relay coil draws about 170 mA (0.170 A). Each solenoid draws about 15 amps. Since all of the solenoid load current now passes through the relay switch contacts, the electrical system will never get hot as it did before, and all of those rare switch contacts will breathe much easier.
While I was at it I also rebuilt the Dash Power Switch.
With all rebuilt switches, restored/repaired wiring and all terminals, rebuilt motor, pump, valves, and solenoids, along with added fuse and solenoid relay protection, this power top system will hopefully last a long time.
Rich
Rich
