67 heater box sealant - NCRS Discussion Boards
  • James B.
    • December 1, 1992
    • 281
    I am restoring my '67 coupe, now have the body off the chassis and am stripping everything out of the engine bay. A black sealant was used around the heater box, grommets and other areas on the firewall (and liberally dripped down the firewall!). What modern sealant would y'all recommend that matches the original and is acceptable in judging? Once I have that then I will have to practice to be as sloppy as the guy who originally did the job. Thanks, Jim B
    edit: After I post something then I think about the archives, so apologies. However the posts on this subject appear to be about 8-9 years old. The most specific was from Joe Lucia, "For C2 era cars, the AIM says that the sealer used for the blower box to firewall interface was neoprene solvent adhesive. This is the same type of cement used for gaskets, weatherstripping, etc. It's what we know today as 3M Weatherstrip Cement aka GM #12345097." Is this still the best answer?
  • Ara G.
    • January 31, 2008
    • 1108
    Re: 67 heater box sealant
    James, there are 2 schools of thought on this issue I think. One believes that the sealant was really used only on the "leakers". I have seen Bowtie cars with the sealant, and without (or very minimal). Tough call to make. Joe's response is a good one in that older post. Other schools of thought believe that all the cars got the sealant to keep water from coming into the passenger compartment from the engine bay. I have seen guys use gritty asphalt/tar, black weatherstrip glue, etc....The consistency, IMO, is close but not exactly like the original stuff....I am sure others will chime in....ARA
    • James B.
      • December 1, 1992
      • 281
      Ara, thanks for the response. I've done some more reading. Comment by John Hinckley and other that it was only applied to leakers is interesting. Guess I have a leaker. I'll go look for submarine sealer....
      • Daniel Y.
        • September 30, 2002
        • 185
        James - I've used plastic roof cement (caulk) to fill the huge cracks and then fibered roof cement on top of that or in tighter cracks. it runs down just like the original did
        Dan Young
        65, 67 Duntov x2
        66 bowtie x 2
        71 LT1 TF
        90 ZR1 McCelland
        03 Anniverary
        06 Z06
        • James W.
          • December 1, 1990
          • 2640
          Hello James,
          There was an article on the Spring 2011 Corvette Restorer Magazine that has info on how to make your own sealant and how to apply it. The author was Duane Ravenburg. I have it in a PDF file if you would like it. I am getting ready to do this same treatment on two of my cars before the national convention.
          James West
          • Chris E.
            • November 3, 2006
            • 1322
            I don't believe my car had the sealant originally. Family owned car since 1973. I did a complete body off restoration on the car, and there was no remnant of sealant anywhere near the heater box on the firewall, nor on the blower assembly. I left it clean and I sometimes lose 1 point in Flight Judging at the Regional / National level. The '67 TIM/JG says "some cars" may have had it. No big deal.
            Chris Enstrom
            2011 Z06, red/red
            • James B.
              • December 1, 1992
              • 281
              Thanks Chris, I read about your debate in the archives (2010?). You may remember you judged my car (white/saddle '67 L79 Coupe) at Delafied in Sept. It should be ready for you to judge again late 2015! Trying to retain as much originality as possible. Jim B
              • Gene M.
                • April 1, 1985
                • 4232
                Guys, I think you will find that the slop and drip sealant job was only applied to cars that leaked the water test. If John Hinckley will chime in he should be able to completely explain the topic best.
                  • 6940
                  I have had 3 heater boxes apart on mid years lately (non-a/c) and re-call no sealant on any. But would say use a little 3M strip chaulk behind the sealing gaskets and studs should be done regardless.
                  • Chris E.
                    • November 3, 2006
                    • 1322
                    Jim, I do remember you and your car! Glad to see you are continuing to campaign the car. Let me know how else I can help, as you and I have the same model year and motor. I should be at the 2015 Delafield Regional. Hope to see you there!
                    Chris
                    Chris Enstrom
                    2011 Z06, red/red
                    • Gene M.
                      • April 1, 1985
                      • 4232
                      Here is John Hinckley reply on the topic from previous post.
                      John Hinckley (29964)
                      Join Date
                      December 1st, 1997
                      Posts
                      15,840
                      Re: Heater box sealant
                      The gooey, runny black stuff was a water-test repair sealant that was used in repair and intermittently on the main line; it wasn't part of the normal heater blower case installation.
