'67 Tank Sticker Removal - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    What is the easiest way to remove a tank sticker without damaging it and without removing parts? Thanks
  • Donald O.
    • May 31, 1990
    • 1580
    Re: '67 Tank Sticker Removal
    If you want to remove the tank sticker from a 1967, you have to drop the tank. There's no way around that, IMHO.
    DonO
    • Larry B.
      • October 21, 2010
      • 254
      Thanks Don! Is there an easy way just to view it and see if it is there?
      • Donald O.
        • May 31, 1990
        • 1580
        Scrunch the black rubber filler neck boot out of the way and and use a flashlight to check the top of the tank. Check both sides too.
        • Larry B.
          • October 21, 2010
          • 254
          Got it. Thanks
          • Tim G.
            • March 1, 1990
            • 1358
            It's much easier on a coupe. You're looking for a piece of paper that may be covered in dust.
