A Corvette Video - NCRS Discussion Boards
A Corvette Video
  • Peter S.
    • March 28, 2012
    • 327
    Re: A Corvette Video
    Really impressive Joe. Time to change the license plate?
    • Joe C.
      • August 31, 1999
      • 4598
      Nah.
      That's one reason why it's a "sleeper".
      • Gary R.
        • April 1, 1989
        • 1796
        #18
        So JoeWhen are you going to add a steel cap to the diff and tune it! You want to keep it together when you launch the car!
        • Joe C.
          • August 31, 1999
          • 4598
          #19
          When I first built this car, and it was still a L76 I mounted 7.75/15 Goodyear Power Cushion Goldlines to the knockoffs. As time went by, the goldlines wore out and were replaced with Pirelli P4000s while the engine was upgraded in 3 steps from a stock L76 to what it is now.
          The driveline is stock, except for a RS600 5 speed (Ford T45 with special case for C2 Corvettes). SBC halfshafts and straps, not caps on the yoke u-joints. I broke one stub axle years ago, and replaced it with a unit from International Axle. All has been well ever since.
          The idea of the skinny Pirelli tires (210/70-R15) is to help prevent drivetrain breakage.
          The diff is a 3.70 posi which I built up.
          • Gary R.
            • April 1, 1989
            • 1796
            #20
            Joe Int axle makes good parts. The 210's will burn up usually before any damage. I'm going over my son's 12 bolt IRS now, he sheared both LH inner/outer spicers last time out at the track. It has about 400 hp at the wheels, not too bad for a SB with a mini blower on it.
            • Joe C.
              • August 31, 1999
              • 4598
              #21
              Good power.
              I should have said earlier that mine is a normally aspirated 327 using a dual plane intake (Z28/LT1) and a 750 dual feed carb from QF.
              No nitrous.
              No cold air induction (yet).
