Re: '67 hood won't open
Leif,
Don't know if you've solved your problem yet or not. I offer a possible solution to the problem but I have not actually performed this on my car. It's theory at this point but what the heck it seems plausible. Using my 65 AC coupe as a "test bed" I found that a 3/4" dowel fits nicely up between the AC hard lines next to the box and there is ample room to move the top of the dowel forward and backward. As you can see in the attached PDF, I made a hook from a coat hanger and screwed it to the end of the dowel. If you can manage to get the hook onto the latch lever that holds the return spring, you can probably push the dowel forward to release the catch. Another possibility might be to put a block between the dowel and the firewall and pull back on the dowel to move the hook forward. The dowel I had on hand was 22.5" long. A longer piece would probably be easier to work with from under the car. Again, I have not successfully deployed this method but it seems as though it might have some potential in getting to that passenger-side latch.
Dave Z
Stuck Passenger Latch - Mid-year Corvette.pdf
Leif,
Dave Z
