1969 and 1970 Corvette Vinyl Shifter Console - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi All,
    Can someone explain the differences between a 1969 vinyl shifter console and a 1970 vinyl shifter console?
    Dave
    Re: 1969 and 1970 Corvette Vinyl Shifter Console
    Originally posted by David Schutzbank (50698)
    Hi All,
    Dave
    Dave------
    The primary difference is that the 1970 forward console has "stitching" around the upper perimeter. The 1968-69 forward consoles do not have this "stitching". The 1970 console can be used to SERVICE 1969 applications, but it's not correct.
      • 15573
      I believe there is an additional difference in the configuration of the front of the console. I remember an event where Jay Kellogg (one of the seven NCRS founders) explained about this. He worked for the Inland Guide division of GM and was tasked with solving a shipping problem with the 1969 consoles. There were "points" on the front that suffered an unacceptably high rate of damage in transit to St Louis. A redesign of the front, and the small close-out panels on each side for the 1970 and subsequent model year solved that problem.
      We were blessed with a 1969 & 1970 with reasonably original interior that he used to demonstrate his story. The above is my "cliff notes" of what was about a 45 minute impromptu "tech session." And yes, some of us got into it with him about the jigsaw-like complexities of the interior pieces. It was another of those you-had-to-be-there events that make NCRS meets so rewarding.
      • Michael F.
        • 745
        Terry, who were the founding members of ncrs??? thanks.
        Michael
        70 Mulsanne Blue LT-1
        03 Electron Blue Z06
          • 15573
          On the Masthead on Page 3 of EVERY issue of The Corvette Restorer:
          John Amgwert
          Dick Campbell
          Joe Chess
          Tom Essig
          Sam Folz
          Jay Kellogg
          Gary Mortimer
          Edit add: I confess I cheated and looked in the last Restorer just to be sure I spelled the names correctly. It was the least I could do to honor those fellows who stood up to be counted, when it counted the most. I believe the next issue of The Restorer will have much more on this subject. Be patient grasshopper.
          • David S.
            • August 9, 2009
            • 595
            Thanks Guys.
            That said, if the 1970 - 1972 consoles these same? Yes I have an original for my late production LT1 but the thing is cracked beyond repair. I need to round up a solid original.
            Dave
            • Warren F.
              • December 1, 1987
              • 1516
              1970 is slightly different from '71 & '72.
              • Paul O.
                • August 31, 1990
                • 1716
                Thanks Guys.
                Dave
                Dave in actuality all 3 years are different to a degree. A 1972 does not have fiber optics so no front slot or opening. Plus I do not remember what the slight difference between a 1970 and 1971 is but I am sure some will help with that difference.
                • David S.
                  • August 9, 2009
                  • 595
                  Thanks Guys.
                  Dave
                  • Patrick B.
                    • August 31, 1985
                    • 1986
                    I don't understand the reference to "vinyl". Isn't the shifter console made out of pot metal?
                    • Warren F.
                      • December 1, 1987
                      • 1516
                      You may be thinking of the shift console plate that attaches to the top of the forward console.
                      • Patrick B.
                        • August 31, 1985
                        • 1986
                        yes, I was.
                        • Dennis D.
                          • March 1, 2000
                          • 1071
                          I believe there is an additional difference in the configuration of the front of the console. I remember an event where Jay Kellogg (one of the seven NCRS founders) explained about this. He worked for the Inland Guide division of GM and was tasked with solving a shipping problem with the 1969 consoles. There were "points" on the front that suffered an unacceptably high rate of damage in transit to St Louis. A redesign of the front, and the small close-out panels on each side for the 1970 and subsequent model year solved that problem. We were blessed with a 1969 & 1970 with reasonably original interior that he used to demonstrate his story. The above is my "cliff notes" of what was about a 45 minute impromptu "tech session." And yes, some of us got into it with him about the jigsaw-like complexities of the interior pieces. It was another of those you-had-to-be-there events that make NCRS meets so rewarding.
                          I thought the snipped tips of the left and right lower consoles started in the 71 model year. Which changed the front design of the center console to a tab type design locking in the pieces. Those 2 designs don't interchange
