When I start up my 68 after it has been sitting (no vacuum in system), the wiper door moves slightly about 1/4 inch up/down. I know this can be an indication of a leak on the control side of the vacuum system. All the hoses have been replaced as well as the relays. Remaining existing components have tested OK. I have tested the system and it holds 22 " of vacuum - no leaks. Is a slight amount of movement 'normal', or have I missed something?
I do have some leakage on the heater/ air conditioning vacuum system. However, this is separate from the wiper control system so I don't think it would cause the door movement.
Any comments would be appreciated.
Dan Leslie
Dan Leslie
