Water pump stud/bolt
Re: Water pump stud/bolt
Roger that bolt w/stud would have been black phosphate finish from factory, I believe as all the pump bolts on my 72 are black phos. , and that Bolt on w/pump was left un painted. As it goes the factory remove and replaced the painted bolts that have brackets attached to them, So being the alternator bracket is attach to w/pump ,it should have no paint.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Edward so I understand. in 69 should all the water pump bolts be orange and just that head between the bracket left unpainted, or is everything black except for the bolt between the bracket. Sorry I am a little slow.Roger that bolt w/stud would have been black phosphate finish from factory, I believe as all the pump bolts on my 72 are black phos. , and that Bolt on w/pump was left un painted. As it goes the factory remove and replaced the painted bolts that have brackets attached to them, So being the alternator bracket is attach to w/pump ,it should have no paint.- Top
I would suggest that everything you show as zinc in your photo should be black phosphate.
I believe this would include the zinc bolts you show as holding on the power steering bracket.
There were few, if any, zinc bolts used on your engine.Vice-Chairman (West), Michigan Chapter NCRS
Okay it seems that there may be 2 answers 1 all black and one all black except for the zinc bolt to the pump. Very surprised it was not orange but I do understand now.Thank You GentlemanRoger- Top
