Can anyone snap a picture of the mounting position of the brake light switch on the brake pedal assembly with auto trans? The support bracket I have appears to have the light switch bracket welded in the wrong place. Does anyone know where I can purchase a brake pedal assembly or just the mounting bracket with the 4 studs that goes through the firewall for a 67 with auto transmission? I know 67 is different than previous years because of steering column changes.
1967 corvette brake pedal assembly
Re: 1967 corvette brake pedal assembly
Al -Can anyone snap a picture of the mounting position of the brake light switch on the brake pedal assembly with auto trans? The support bracket I have appears to have the light switch bracket welded in the wrong place. Does anyone know where I can purchase a brake pedal assembly or just the mounting bracket with the 4 studs that goes through the firewall for a 67 with auto transmission? I know 67 is different than previous years because of steering column changes.
Photo below shows a '67 pedal support assembly - manual and automatic supports are the same part - they just use a brake pedal with a different width pedal pad. Power brakes adds a bolt-on paddle on the pedal arm to actuate the brake light switch, deletes the pedal return coil spring, and deletes the two bottom studs at the firewall.
PedSupt2650.jpg- Top
