Gentlemen,
I have a early 66 327/300 auto (powerglide) built Oct 65. I have replaced the shifter mechanism and the neutral safety switch/harness. When I start the old gal she does as she should when in park. But when she's in neutral there's not a sound. Now, if I push the shift leaver forward approximately 1/2 inch (not depressing the shifter button) with the ignition switch turned to start, she starts. Question is; how do I adjust the switch to start in both park and neutral? I don't want to fix something that doesn't need fixing. On the bottom of the shifter housing, the neutral safety switch attaches to the shifter with a bracket and two screws. Each of the two screw holes is elongated, apparently to allow up and down adjustments (I think). I need some "how to" guidance from you wise fellows , please.
Ken Bryant
42259
Ken Bryant
42259
