Re: Wanting to switch my 1967 L71 to manifold vacuum
Joe,
Thanks for the information. I am not a member of the St. Louis chapter, however I purchased the car from Randy Rapp and have many friends who are members. I do have the B26 can that Duke recommends and it is rated for 16 degrees vacuum advance and that works perfect with 8 degrees initial advance for a total of 24 degrees advance at 800 rpm idle speed. My distributor mechanical advance is set up for only 20 degrees (factory should be 30 degrees) thus requiring 16 degrees initial advance. My focus currently is finding a way to modify my B26 can or another one better suited to limit the vacuum advance to 10 degrees. With the vacuum advance disconnected, the car performs flawlessly to redline with no detonation. Just trying to eliminate the light detonation between 1500 - 2500 rpm with light gas pedal pressure.
Thanks Chris
Joe,
Thanks Chris
