I am restoring my 63 convertible, built august 63. My question, do the lower A arms have the reinforcement. Since it was late build. Thank you.
Restoring my 63 conv.
Re: Restoring my 63 conv.
I only have the 5th addition of the judging manual handy and based on that early to mid production 63's did not have the reinforcement. My mid May 63 does not have the reinforcement. But you car is very late production so I would think you should have it.- Top
- Top
Stu -
See the two photos below. The one with the frame upside-down shows the front sway bar link bolt being installed, and the bolt goes through a single stamped bracket welded to the front of the lower control arm; early cars (as shown) only had that single-thickness bracket, and it wasn't strong enough to take the link bolt loads without bending.
The other photo shows a '66, and you can see the added reinforcement from the control arm to the bracket that provided the stiffness required to stop the failures - that reinforcement was added during '63 as a running change.
66L79DropFrt (3).jpgFrtAssy1 (2).jpg- Top
