Thanks Keith
Wheel bearing front & back 1963
Re: Wheel bearing front & back 1963
No need to replace the spindles unless they are damaged or undersize. The rear bearings are a press fit, when you drive out the spindles if the outer bearings stays on they usually are ok to reuse once you check the other areas. If the bearings comes off then they are probably undersize. I have replaced many rear bearings and many original spindles are still good. Note the 63-64 drum brake spindles are different then the 65-82 disc brake spindles.- Top
