Hi everyone Two Questions. Im having trouble getting my rebuilt master cylinder to seal at the two big bolts on the end. I have new crush washers in on the smaller bolt. Re using the big one. I pump it up to 15 psi with soaped joints but not holding there. Do any of you use teflon tape on screw threads or other sealing methods. Also, should all piston cups in wheel cylinders move easily with finger pressure? Ithink I might have to take the rubber covers off the cylinders and soap the pistons to see if they are holding. This beats using fluid to find leaks. Thanks again!!!
