Alternator Pulley needs cleaning - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1273
    I have a f/I car with a zinc pulley on the alternator and it needs cleaning. I've tried various polishes, etc. but nothing cleans it.Can anyone recommend any "solution" to use to clean this pulley? Thanks
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Alternator Pulley needs cleaning
    Gerald,
    The pulley should be steel with a zinc plating. What is on the pulley that needs cleaning, road grime, rust, corrosion? Maybe is the plating wearing off? If the later it needs to be replated.
    • Gerald C.
      • June 30, 1987
      • 1273
      Gene,Thanks for your reply. I think I might just have it replated or replace it.Jerry
        • 15573
        Jerry,
        Have you tried Rub & Buff? Available from the big box craft stores -- Hobby Lobby, Michaels, etc.
        • Jerry K.
          • December 1, 1981
          • 93
          Clean with Simple Green, and then lacquer thinner. Then polish with a product called Rub and Buff, sold at Michael's Craft shop. It is the easiest way to brighten up a tarnished cad or Zink plating. A very little goes a long way, as you will see.. Q-tips or cotton balls are what I used on my windshield washer motor, hood hard ware and an assortment of bolts and other items. Comes in silver, gold and black. Good luck....
          • Gerald C.
            • June 30, 1987
            • 1273
            Hi,
            Trying most of these materials, I think I will need to repalce the pulley. I would asssume it will be less expensive to repalce it than to re-plate it.
            Thanks for the feedback.
            Jerry
            • Timothy B.
              • April 30, 1983
              • 5177
              Jerry,
              If that's a original pulley I would always use that instead of any reproduction part. Get the silver rub and buff and give it a try, you will be surprised.
              • Gerald C.
                • June 30, 1987
                • 1273
                Thanks. Will pick up Rub and Stuff today
