Re: Exhaust heat abatement on mid year
Here's a lesson I learned about cabin heat. There's a lot of threads in the archives about cabin heat, with some great advice including: check for missing or worn grommets in the firewall and console, check for torn lower shifter boot, check tunnel insulation, check operation of plenum air doors, check hood to cowl seal in the firewall and console, and check for body seam gaps in the AC/heater plenum.
But there's one more thing I did that really reduced radiant heat along the bottom of my '70's console: I rerouted the exhaust pipes that were within 1/2" of the fiberglass floor near the tunnel- good for ground clearance, not so much for cabin heat. The exhaust is not original and I believe was installed closer to the floor than OEM. Increasing the exhaust-floor clearance (in my case, by 1/2" - 3/4") reduced radiant heat significantly.
Is there a factory spec/tolerance for exhaust-floor clearance? Nothing in Section 8 of AIM (for 1970).
