54 shifter handle replacement - NCRS Discussion Boards
  • Jerry H.
    • April 22, 2007
    • 8
    I have had the shifter handle off of a 54 Corvette for several years. Upon replacement, I had a threaded stud with a fixed nut and smaller threaded end (for mounting the bell cover). Putting the longer threaded end into the tunnel's hole, it does not seam to want to bottom out or seat (before it seems to be in too far). I can't remember if there was any other parts involved. The shim with the detents for the shifter handle are screwed to the tunnel. The transmission has not been messed with. I have not looked underneath yet. I thought it just threaded in. Thanks for any help, Jerry
  • Gary H.
    • June 30, 1980
    • 155
    Re: 54 shifter handle replacement
    026-collage66.jpgThis might help!
