Replacing my rear crossmember on my 58. Does the new rivets go in from the bottom side and rivited on the top side. My old one was bolted on which I know is not correct.
58 rear crossmember
Tags: None
- Top
Re: 58 rear crossmember
Keep in mind the frames were assembled upside down so the workers would drop them in and buck them. When you looked under an assembled car, you would see the head. (double checked my 58 just to be sure).
Tom1958, 283/245, White/red - Top Flight, October 2016
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
Thanks Thomas, that is how i thought they are installed but I have seen them installed with the head up on some cars.- Top
The original rivets were set (cold) using a 2000 psi hydraulic rivet-setter, similar to those used next door on many locations on the Truck frame line. With that kind of tooling, heating wasn't necessary.
Riveter800.JPG- Top
Dino,
I cut off the old rivets. Welded the replacement bracket onto the frame. Then welded the rivet head and ends in place.
Gary
....NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
