I have searched the archives but can't find it. What is the recommended plug wires with right angle ends (65 with FI)? Thanks, Don H.
spark plug wire
Re: spark plug wire
i buy the repo plug wires from lactic limited for my FI vets. since they have carbon cores(which are fragile as hell) i remove all 18 boots and all 18 metal terminals from the repo wires set. i then cut 8 plug wires and the coil wires to length from a spool of packard 440 plug wire(which has a steel cores tough as nails). then install repo boots and terminals. after silicone pasting the boots and sliding them on the packard wires, i solder the cores to the repo terminals. use lacquer thinner to remove the packard stamping and then if u are having the car judged , get rubber stamp pad made with the info(RTV and dates) stamped on the repo plug wires. good luck,mike- Top
