1965 - 365hp flame arrestor grommet - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    Hi Guys;
    On my 65' 365hp convertible, I have the original air cleaner unit and flame arrestor on the base. The flame arrestor sits directly onto the metal base. I recently bought a flame arrestor rubber grommet from Long Island Corvette, however; I'm not sure it's required. I might have mixed up the application. The part number at Long Island is 22-08C & 22-11B. Was there a rubber grommet installed at the factory between the flame arrestor and the air cleaner base ? Thanks in advance.
    • 6940
    Re: 1965 - 365hp flame arrestor grommet
    David, I do not recall a gasket on the flame arrestor, It just a press fit.
      Originally posted by David Kalaydjian (21729)
      Hi Guys;
      David -
      Those are big-block parts - 22-08C is the rubber grommet for the in-line flame arrestor that goes in the driver's side valve cover on a '67 3x2, and 22-11B is the rubber grommet in the '65-'67 BB pass. side valve cover where the breather tube elbow from the air cleaner base inserts. The flame arrestor on the 327/365 is a press fit on the tube inside the air cleaner, and doesn't use a grommet.
      • Ara G.
        • January 31, 2008
        • 1108
        David, also check to make sure your flame arrestor is original. Known originals had the 4 dimples on the top of the screen and also had "GM" stamped on the base of arrestor in 2 places (both directly across from eachother - meaning one stamping at 3 o'clock and the other at 9 o'clock). ARA
        • Wayne M.
          • March 1, 1980
          • 6414
          Like this --
          • David K.
            • 281
            Thanks guys; I checked & it is indeed original.
