Anyone notice (notice/complain) about this back when their cars were new ?
From Chevrolet Dealer Service Info Bulletin (blue), dated 23 March 1967:
With the 7.75 x 15 tires, a 3.70 ratio calls for a green plastic 22-tooth driven gear (3860345), coupled to an 8-tooth steel drive gear (3708145). This is the same as for the two previous model years which also used 7.75 rubber.
But the same combo drive/driven is quoted for the 3.55 final drive ratio. so one or the other will be off calibration by ~5% [or both, partially, to a sum of ~5%].
Prior to 1967, the 3.55 took the red plastic gear (21-tooth) with the other 8-tooth steel drive gear (#3708144).
I notice there were other changes in '67 (ie. the 4.11's in prior years took the yellow 24-tooth plastic gear; but in '67, they call out the 25-tooth orange). And there's more.
Was there something different in the '67 7.75 x 15 tire, compared to '65 and '66 ?
c
c
