1954 tranny burping article - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    I thought this might be useful as I might do it.cipgleaks2.jpgcipgleaks1.jpg
  • Troy P.
    • February 1, 1989
    • 1279
    Re: 1954 tranny burping article
    Very interesting Guy. If you are thinking about going to the trouble of putting a vent in why not disassemble and put the pin back in the hole?
    • Gary H.
      • June 30, 1980
      • 155
      If you are still having trouble with trans belching fluid, try shutting it off in gear(D) and then put it in P.
      • Guy M.
        • November 1, 1993
        • 499
        Hi Guys, I wont know if the pin is there until I open it up. If I read that right, the pin should be in there for it to work properly.
