New here and my first post.
A friend recently purchased a 1968 Corvette with a not original small block engine in it. Also has a small block hood. Trim tag shows PAINT 900=Tuxedo Black and TRIM 414= Medium Blue. Serial #424032 would be a July 1, 1968 build date.
After he brought it home I had a look and noticed it had a high rpm (6,500) red line tach. Did a a little research and discovered that tach would indicate an L71, L89 or an L88 engine. So I did more research to see what other telltale signs I could find to indicate the original engine. Here's what I have so far:
Single fuel line from tank to pump.
Three holes in fenderwell for K66 TI
6,500 RPM redline tach
It also has a big block radiator and shroud and F41 suspension. I believe this would all indicate either an L71 or L89, right? Is there anything else to look for? This car has no documentation so I guess it doesn't really matter but I would just like to document as much as possible.
Just got the shipping data report which says, "The original delivery dealer was Dealer code 1, Zone 21. The name and location for the dealer was Foreign Distributors Div/Export" After a little research I guess this frequently indicates the car was purchased by a G.I. while overseas and picked up at a dealer in the US. Any way to find out what dealer?
Maybe while cleaning out the interior we'll find a build sheet. . .right.
Hey, doesn't hurt to hope right?
Can somebody fill me in on the location of the transmission numbers and how to decipher them?
