63 wheel cylinder removal - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2155
    I'm trying to remove the pin that holds on the front brake wheel cylinder on one of my 63s. It doesn't want to come loose, not even with several days worth of spraying with PB Blaster. Anyone got any ideas?
  • Harry S.
    • July 31, 2002
    • 5258
    Re: 63 wheel cylinder removal
    Mike, I don't recall a pin?? I just went through my pictures.....
    • Edward J.
      • September 15, 2008
      • 6940
      Mike that bolt has a pretty big Diameter and a deep socket with a long breaker bar should work, and if you have a small compressor and a impact gun try that. Also there maybe a retainer tab that is bent over to lock the bolt.
      • Michael G.
        • November 12, 2008
        • 2155
        Harry, its the spring retaining pin, the one that goes through the mounting hole in the cylinder and threads into the spindle. The pin has a hex and threads too, so I suppose some may call it a bolt.
        Edward, already tried a breaker bar with a "cheater" pipe, also an impact gun at our building's full air pressure. No luck...
        I may go to a gun store and get some Kroil...I've read here that its better than PB Blaster
        • Harry S.
          • July 31, 2002
          • 5258
          Mike, can you post a picture with a photoshop arrow pointing to the problem.
          • Edward J.
            • 6940
            Mike, sounds like heat will be the only thing left, not sure that any penetrant would work. Penetrant is not always a cure all. a lot of people here swear by it. I have tried them all over the years. the best stuff I have ever used is heat riser penetrant that GM use to make years ago. also mopar had the same stuff.
            • Michael G.
              • November 12, 2008
              • 2155
              Yeah, I was hoping to avoid using heat while the assembly is still on the car, but I certainly don't want to take the knuckle off.
              • Michael G.
                • November 12, 2008
                • 2155
                Harry, Here's where its used
                With a little Kroil and and bigger impact wrench, I got the pin/bolt off. Now the hex corners are pretty well messed up. (see pic) I'm wondering where the heck I get one of these (in good shape). Any suggestions would be great.
                • Gary F.
                  • August 29, 2010
                  • 248
                  Corvette Central....Front or rear $20.00 (anchor pin )
                  • Michael G.
                    • November 12, 2008
                    • 2155
                    Thanks, Gary, assuming that the other side will be just as tough, I ordered two...
                    • Gary F.
                      • August 29, 2010
                      • 248
                      GOOD DEAL!!! Both of mine were covered in pure rust, so I went the same way.
